Wiring help
I have 2 batteries under the hood. I am running my power off the main battery now. Would I get more voltage to my amp if I run a ground from the back to the main battery and another power wire from my secondary battery and even run another power from the main
You would do better by upgrading you power wire from your alt to your main battery and the ground up front from the engine to the frame or strut bolt. As far as the power wire to the back it depends on what guage it is and what you are running off of it. You'll need to provide that info to get better help.Plus make sure you are grounded from the rear battery to the frame or a strut bolt.
  • Who's Online   0 Members, 0 Anonymous, 1427 Guests (See full list)
