Looking to have a custom box built...
nvmyv8
Mods, please feel free to move this post if it isn't in the appropriate section of the forums.
I'm usually the type to take my time and do it myself when it comes to design/install, but unfortunately I don't have access to a table saw or a router to properly get this done on my own.
With that said, what I am looking for is someone who would be willing to build a factory spec sealed wedge enclosure for a JL Audio 13W7 driver.
After measuring my car's trunk space, here are the maximum box dimensions I have to work with: 28"W x 15.5"H x 14"BD x ~10"TD. The desired net box volume is 1.875 cu. ft. The top depth is variable to achieve the required clearance of 0.75" behind the driver magnet. Otherwise, the width should be the main variable in achieving the proper internal volume. The use of 1" MDF all around would be great, but 3/4" on all sides but the front would be acceptable should the physical dimensions become a limiting factor.
Below is a quick sketch I threw together the other night along with a couple of pictures I found online that closely resemble the shape of enclosure I have in mind.
I am located in central PA, but do travel to NYC/Baltimore/DC quite often and would be willing to pick this up to avoid shipping.
Any high quality builder recommendations would be appreciated.
I have a awesome guy in pa.
Pm me your contact info and ill have him contact you.
His name is jason
  • 2 months later...
thats a nice looking box!
audio related merchandise (decals,banners,lanyards,hats,shirt,etc)
Thanks! Here's a temp install shot. the amp will be turned around for a cleaner look once I'm done tweaking it. I also need to replace the ratcheting strap for a black one.
  • Who's Online   0 Members, 0 Anonymous, 578 Guests (See full list)
