I need help with a new box.
TigerTony
Well.. I built a Box for my SA E-15 and I made the height Just a little bit too big for the opening in my buick.
For the Sub to be facing backwards and the box to fit through my truck opening it has to be 15" in height which i Just found out a little bit ago. Anyways.
If I were to do Sub up port back in a Trunk, Would that sound okay inside of a trunk? I know i can do a ported box thats sub up port back on the drivers side
Or Any ideas?
usually sounds like crap that way. had my CVX 12's like that waaaaaaay back when. hated every second it was like that
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
well you can slant the front of the box, or try a bandpass with the sub facing up or slanted.
More box builds
Oh. Well. with my box at 17x24x23. I just went to measure it out by setting it in. and it gets stuck with about an inch away from dropping into the trunk.
What if i did 17x24x20. Or would that not solve my problem. It might be a little too long still?
Edit: I don't think i have enough room for a bandpass.
First box, When i go to put it in, Its 2-3 inches away from fitting into the trunk.
Would this work? Or should i make the depth a little shorter.
  • Who's Online   0 Members, 0 Anonymous, 1011 Guests (See full list)
