ok so i cant get my volts up any higher then 13.8={ I have 3 xs xp3000 in back one xs d3400 up front. and hade a dc power 270sp that would only charge at 13.8.. now i just put a dc power 300 spx in and nothing as changed, well the alt is charging at 14-14.1. when i called dc they said they should be charging at 14.8....I WISH
any body now what could be going on
oh and i have two guns of (+) and two runs of (-) from front to back...... idk im lost
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Mids/Highs Amp-MB QUART ONX4.125
Mids/Highs- Undecided
Sub Amp-DC Audio 7.5
Subs-4x DC Audio xl 18s
Alt- 270sp & 250sp Dc Power
Big 3 1/0
http://dcaudio.us/
SPL-LAB sells rep. for IOWA
http://spllabusa.proboards.com/
i thought i told u my story but more grounds help a lot or its the batts but i think a ground or two could help
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
7 Xs D3100s & 1 D6500
All Audio Techinx OFC 1/0
Doing 55s at 26hz!!!
You can
1. Take off alternator and the bracket holding it, and clean off the metal contacts to engine block
2. Moar wire
3. Moar grounds to engine block or alternator/bracket
Edit:
When I put a new crate motor in my truck I took off the alt bracket and painted it black and it covered the metal where the bracket connects to engine block.
I removed it again and cleaned the paint off and got a nice clean metal finish and just that along with my current wiring jumped me from 14.6 to 14.9v
Edited by Loslam
1997 Chevrolet Silverado Extended Cab, 350 Vortec
Things to come at some point...
Build Log: http://www.stevemead...2200ds-133-ohm/
Here what you can do instead of listening to people who are just guessing at what to do, actually test for the problem....
Follow these steps
1. Get a DMM
2. disconnect your rear batteries, just have the one batt underhood
3. Put DMM to DC voltage
4. Read voltage at front battery- write down number or remember it(TRUCK OFF)
5. Keep POS probe from DMM on the battery
6. Put Neg probe from DMM to the alt case
7. Is voltage is different then reading direct at battery - Yes or NO
8. If step 7 is Yes - you have a ground problem add more grounds
9. If step 7 is No - you have a possible weak alt regulator or very bad connections
10. You are done report back here
This best I can give without actually being there and seeing what is going on, could be something simple you are overlooking.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Follow these steps
1. Get a DMM
Ok so I'm reading 12.56 at both
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Big 3 1/0
http://dcaudio.us/
are you trying to get a higher resting voltage or just less of a drop? Im assuming your amp is 7500 watts... Your not gonna get much bettter voltge drop with one alternator and that much current draw. You can start off with higher voltage but it will fall to just about the same thing.
  • Who's Online   0 Members, 0 Anonymous, 1662 Guests (See full list)
