Cleaning out garage sale
Audiocontrol eqq
4Ch EQ/Line Driver:
Dual 12 band EQ's
>5-bands half octave EQ
>7 bands of full octave EQ
7V line driver
Input and Output level matching Controls
Defeatable EQ button
Subsonic Filter
100.00
Autotek mm75.4
Autotek Mean Machine Series 4-Channel Class A/B Car Amplifier
RMS Power Rating:
4 ohms: 75 watts x 4 chan.
2 ohms: 125 watts x 4 chan.
Bridged, 4 ohms: 250 watts x 2 chan.
MOSFET power supply
LED power indicators (green/power, red/protect)
Bass Thrust - Variable Bass Equalization (0-18 dB @ 45 Hz)
TCID (Twin Coil Isolation Design)
4-Channel operation
4-way protection (DC, short, thermal, overload)
Aluminum autoTek illuminated shroud
ASPS (Auto-Step Power Supply)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable High-Pass (10-1200 Hz)
Variable Low-Pass (50-150 Hz @ 24 dB)
Subsonic Filter (10-1200 Hz @ 24 dB/octave)
Frequency Response: 10-30,000 Hz
Dimensions: 13-3/4"L x 10-1/4"W x 2-1/2"H
100.00
Custom oz 18
OZ 4" motor with spaced 6 spoke bakset w/gasket
4" D1 4 layer Alum flatwound coil with vented former
tripple sewn leads
direct connects
paper cone
black poly dome.
4K RMS
275.00
2 custom built 10s
mmats pro audio motors,
single four ohm
can take from 500-750 rms,
sa-10 soft parts
85.00 ea
HEADUNIT:Pioneer AVic d3
WIRING: 8 runs of 1/0 knu gnd and pwr
BATTERIES: 1 shuriken bt80 upfront 4 in the back
COMPONETS:powerbass 3xl in front dooors powerbass xl in back doors 6.5s
AMPS: 2 powerbass xa3000d powerbass Asa 400.4
SUBS: 4 db drive plw 15s
ENCLOSURE:12.7 cubes 32hz
ALT: 150a stock for now
VEHICLE:05 chevy trailblazer sitting on 24s
iTRADER FEED BACK http://www.caraudioclassifieds.org/forum/itrader.php?u=1289
1 10 sold
yes
yes it does. took it out so i could run all powerbass amps
To the tizzop
need this stuff gone so i continue my build
18 pending sale
