ok mmm learning more and more :D
i know about the RE's they dont bother 2 get a lil extra, like my old SX's ive gived them 2500 over power daily just one died after 5 months full pull playing
Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps
definitly not the Q's ??
if i want 2 order them will u advice to offer them with coppercoil and BP POWER ???
and was the different between:
flatwind coil and coppercoil
bp power : This new option adds a machined aluminum compression plug to the pole which helps channel all of the air under the dustcap around the coil for better cooling. To aid with this increased airflow we also add 6 axial cooling channels in the top plate. Along with increased thermal capacity comes the addition of an extra spider and a changed spider pack for a little extra mechanical ability.
All of these new features increase power handling from 200-500 Watts depending on the application.
so get it
Flatwound coil– The flatwire coil option simply helps the power handling of the sub. The coil has more surface area to dissipate heat and will take more power then the regular round wire coil that comes in the ‘stock’ version of the sub. This option will also make the sub tend to be more prone to ‘peaking’ for a budget daily driving sub where you don’t have to use a ton of power to get maximum output and sacrifice sound quality a little bit.
copper sounds better and has better transition, but not need in ur case
so get 12 ssd w/bp power!!
ok that helps a lot
just ssd's with BP power and NO flatwound option or copper ?
im almost 24/7 lBUMPING pounding everything. NO burping im also doing like standing with friends outside and let the car playing 30 minutes off full power (volume) so they need to be good and need to play for a long time with full power and low
And yeah its a daily car :D
Edited by dbwesz
