  • 1 month later...
Operation: No Sound Deadener Left Behind has commenced.
Problem: big box of second skin products taking up space in my garage.
Solution: Gut the interior and sound deaden everything.
I've already tackled from the rear seats back, now it's time to move forward and upward.
Thought I'd post a couple pics while I'm waiting on the spectrum to cure.
Before the roof was covered in three layers of spectrum
After 3 layers of spectrum
Floor with second skin damplifier applied and all the jesus christ studs taped off ready for spectrum
First layer of spectrum applied to the floor. Should have just enough to do a second coat.
Mission Status: Used up the last of my damplifer supply. A few scraps are going to be used on my remote wire panel, I think it is the source of my rattle. The last of the spectrum is in the spray gun and will used up spraying the floor, The remaining overkill will be used on misc. trim pieces and the last couple of pieces of luxury liner pro is going in tomorrow.
  • 4 months later...
It's been a while since the last update. Haven't changed anything. Everything is still running top notch and load as hell. I did recently snag a couple of "not working" P1000-1bd's off of ebay for dirt cheap. 1 of them showed up in working order, so I'm not sure what to make of it. The listing said it would go into thermal or protect mode, the guy said it had been too long and couldn't remember. I hooked it up to my 10's to test it and worked perfectly. So I guess time will tell on that one. The other one on the other hand is a different story. It was having power issues. So opened it up and started doing a little trouble shooting. I'll let the pictures tell the story...
Circuit board taken out of the housing
Replaced a couple transistors that seemed a little suspect
And today I got the fets on the power side, along with the gate resistors removed...
Also got the thermal paste and heat sinks cleaned up, but this is a pic of the before
Not sure what I'm going todo with the P1000's. I can't decide if I want to resale them and make a little profit, or save them and start planning the upgrade build. I'm thinking some Fi 15's would sound good. Any suggestions or input????
  • 1 month later...
