hook the dd-1 up to your h/u speaker outs using the supllied adapter and play the 0db 40hz test tone and find its maxed unclipped volume. Hook up your LOC to your h/u and adjust it up while at your max unclipped volume and find max unclipped setting. hook LOC to amp and do it again. You can use -5db or -10db at your own risk at this point.
edit.
What i meant by "do it again" is after setting the LOC and hooking it to the amp, hook the dd-1 to the amp. I didn't say that specifically.
Edited by strangeduck
