d luv Posted May 5, 2012 Report Posted May 5, 2012 I have a 1999 Buick Park Avenue and am getting ready to purchase the things that I am still missing in my setup. My main concern is my Audiobahn 2300hct powering my 2 12" JL W7's at 1ohm. I have a yellow top for the trunk and a capacitor as well, here is where I'm lost as I've never used an extra battery or a cap before. The AB has 4x40 fuses, and I also plan to buy a 4 channel amp that does 75x4 rms {not sure on model yet}. My first question is how many fuses should I run throughout setup? Currently I have a 200amp ANL fuse, should I run this 18" from the battery {front duralast, or trunk yellow top}, or should I run a 200amp ANL at each battery? I Also plan on purchasing a distribution block, should this be fused? If so how big of a fuse for the AB output, how big for the 4 channel output? Should the capacitor be fused also? Should I upgrade the big 3 to 1/0 gauged as well? The wire I am looking to buy is http://www.wireandsupply.com/product_p/sgx-1-fslash-0-fslash-01.htm , will this do or should I step up to http://www.wireandsupply.com/product_p/sgx-2-fslash-0-fslash-01.htm ? I am sorry for the lengthy post but I am really confused, even more confused than you after reading this frantic post. Thanks again for the help everyone. Purchase List High output Alt- Is 200amp enough or should I go bigger? Power/Ground Wire Fuses Wire Connectors Distribution Block Completely
MIKE-2U Posted May 7, 2012 Report Posted May 7, 2012 IMO you should fuse from alternators to batteries. Batteries to batteries. battery to distribution block. the wires off the block i don;t think need to be fused and LOSE the cap and add another battery. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
95legwagon Posted May 8, 2012 Report Posted May 8, 2012 /\ this... and yes upgrade to 1/0 for big 3..... i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks. / LOL My Low Budget Build: Green 1995 Subaru Legacy wagon 147k- $1K headunit- pioneer premier deh-p650-$25 4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50 4 vvme L11 10"s <- $30 shipped a piece 6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more 2 aspm 1300 strapped Selenium 6"s in the front doors on headunit power- for now -$20 quantum tweets in door-for now -$10 boston acoustic 5 1/4 in rear doors- for now-Free big 3 1/0 and 4awg throughout. roof sound deadened (not peel n seal ftw)-free on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test about $430 for everything<----Not bad at all still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
