RE AUDIO RSX or RS subwoofers ? not sure what i got!
I ran mine at 1 ohm final load from my Fosgate
T-1000bd. It's rated at 1350 or so at 1 ohm. I'm guessing it was somewhere near 600 a piece or less in real world numbers. I DO have a fullsize truck with a big battery and 1/0 gauge wiring. The surrounds won't take the punishment for over a year on that power, but the coils were fine and new.
my stuff is nothing special , i have the RE set up in this a 96 ford explorer xlt 800cca battery(new) stock 130amp alt , 4 ga comp wire , i have 2 amps that i go back and forth , powerbass asa. 2000.1 that is 120 amps so like 1200 w RMS or so @ 1ohm also have the planet audio AP 1500d thats 90amps so ya 1000 w RMS @ 1ohm but i run both them at .5 with this setup. i have a new kinetik 1400 to put under the hood and new 1/0 ga wire but im not going to put that stuff in intell i get a new alt. 270alt or something like that. i also have 4 -15'' subs that im not useing at this time... that i put in from time to time just to play lol . think im going to rip the top off the 4 -15 box and put in the 2 -12'' RE and buy 2 -15'' RE to also put in it. after i put all the other stuff in ... DSC02655.jpg
Edited by sbg
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
box now has nice bedliner
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • Who's Online   1 Member, 0 Anonymous, 695 Guests (See full list)
