Well I used the cc-1 to gain match 2 channels on a 4 channel amplifier. There are 2 gain knobs on the amp. 1 for channel 1&2, and the other for 3&4. After using the cc-1 to gain match, one channel was at..... lets say 40 volts and the other that I was matching to was at 30. I can't remember the exact volts. I was using the 40 -5 DB track when doing this. Was I supposed to use another track or should I just use a volt meter to gain match? I Just trusted that the cc-1 was right and left it since its not a big deal if it was wrong.
Any help is appreciated, thanks.
Are you using all 4 channels for subwoofers?
What made you choose that track for the test?
Did you match voltage with the amp filter on full pass or lpf?
Re read the manual.
Then do it how the manual says.
Well, after reading it I did everything it said except I played it at 40 -5 DB which shouldn't really matter. Ill do it again at 40hz but I'm sure the results will be the same.
  • Who's Online   0 Members, 0 Anonymous, 3041 Guests (See full list)
