Posted (edited)
I have a pair of Crunch CRBT-4 Supertweeters that I am going to run on a MB Quart 4.60 amp. Only going to use channels 1/2. Where should I set my xover point on the amp?? Thanks for any help!!
Edited by mrdavebasshead75
You are gonna have to set it to high pass filter (hpf) and I'm not sure what frequency response those supertweets are supposed to run at but normally like 3-4khz
Basically whatever you crossed your mids off at
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
Ok thanks, but since im a noob when it comes to crossovers, how do I know whats my setpoint or where to cut it off? The frequency is I believe 5,000 to 21,000 on the tweeters and yes, im just running the tweets off of 2 channels on the amp. Also, they came with little transistors, do I install these too?
Those 'transistors' are most likely bass blockers that are basically a hpf
And your question about knowing what frequency the crossover is set at- that's what a cc-1 is for ;)
Well it must,be nice to have one but unfortunately, I dont and probably never will anytime soon! Some of us just can't afford certain things, and I would hate to buy something only to use it once.
Other than a cc-1 pretty much the only other way is to guess where 5k is
You can look up if anyone near you has a cc-1 on here ----> http://batchgeo.com/map/93b3e7dfd7ea8496a6f1640587e3e4cf
Ok thanks Pro 7 and all the other guys for your help! Ill look into this cc-1 and see if someone near me has one. If not, ill just have to guesstimate it!
  • Who's Online   0 Members, 0 Anonymous, 758 Guests (See full list)
