Enclosure Help!
Scynte
I'm tossing up between a single 10" Skar VVX or a 12" Skar VVX basically depending on room in the boot. Main concern at the moment after playing with Torres for a bit is the port size. Amp will be a Hifonics GLX 1400.1 wired to 2ohm.
For the 10" box specs are
W: 24"
H: 14"
D: 11"
Port specs (3 common walls)
H: 12.5"
W: 1"
L: 18"
Tuned to around 32htz
12" box specs are
W: 28"
H: 14"
D: 14"
H: 12.5"
W: 1.5"
L: 19"
Tuned around 34htz
Is the width of these enclosures going to cause me trouble?
Car is an EL Fairmont
Mostly listen to Rock, Dance/Techno?? Can never remember what it's called. Thanks for your help!
Edited: Forgot to list amp.
Dimensions given for the box with the 10" with displacement of sub and port is actually tuned to 35s(35.18). 12" box is tuned to 33.15 with displacements. I'd go with the 12" setup, make the port 2" in width, and 28 inches in total length. That tunes you to low 34s and gives good airspace.
  • Who's Online   0 Members, 0 Anonymous, 1068 Guests (See full list)
