no advise?
im going to be replacing the idler pulley and tensioner pulley hopefully nothing to major got fucked up :/
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
Coolant is slick- could be causing the squeak. I wouldn't think you should have any problems....
i dunno i think the idler pulley is squeaking... i just bought a dayco belts (40 bucks lol) and a new idler pulley and washers (my new singer alternator doesnt line up perfectly so im gonna put a washer or two behind the new idler pulley and hopefully that lines everything up)
Clean off thwe pulleys with carb cleaner go to autoparts get a gates belt and adjust the tensioner. I've got a 93 4.3l and my upper rad hose blew and it squeked a lot so carb cleaner and new belt. No more squeek.
It is easy to change the intake manifold gasket(S), The hardest part is the plastic upper intake. When i had the coolant leak at the intake, i also changed the timing chain, timing chain cover, power steering pump, water pump, radiator hoses, valve cover gaskets, upgraded the poppet injectors to the new style spider injectors, changed the O2 sensors, spark plugs, wires, rotor and cap. Some of it was not needed but what the hell. I have 178000 miles on it now. It runs great.
