used to run from trunk to behind radio and connect to factory wiring but now i am running all new wire to each speaker following the path of factory wiring
So you still run up to the radio, and then to the speakers (just with good speaker wire) so your rear right speakrs cable is like friggen rediculously long??? right
yes it is lol.im still trying to figure out the best possible way myself. if someone else knows i better/proper way of doing it i would love to know as well
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
I usually run power down one side, rca's down the other side or middle depending on the vehicle, and speaker wires up the middle and split them off to their side under the dash. Rear speakers just get ran to where they need to go regardless of what other wires they have to cross paths with.
www.facebook.com/BILLatDivineCreationsPhoto
He was taunting me. He's all like "come at me bro!" So I'm like "I'm coming at you bro!" And he's like "hey, fuck you" *chomp*. Then I killed it. I win.
^^^ you have truly taken being a lazy fuck to a new level tonight, an MRE. WOW
I just run the speaker wire down the side they are on and (do my best not to zip tie them directly to the power wire every 12mm as tight as possible). that last part was me being a smart ass. The less distance your speaker wire travel the less chance they have of picking up outside noise. But i've never heard of speaker level wire picking up noise, just rca's.
