MistaCrownVic00 Posted May 19, 2012 Report Posted May 19, 2012 I bought 2 Ascendant Audio Mayhem 15s and I have two questions. 1. I'm undecided as to which amp to get either the AQ3500.1D or the Incriminator 40.1. Which amp do you guys feel would be a better match for the 15s? 2. I have a 2000 Ford Crown Vic and I wanted to know which direction should I have my subs facing for them to BANG facing up, towards the back of the trunk, or facing the back seat? Thanks in advance
varietyguy Posted May 19, 2012 Report Posted May 19, 2012 I personally would suggest facing them up and doing a cut through on the rear deck. As far as power I don't know much about incriminator so I cannot give an unbiased opinion. But I had 2 Mayhem's and I had 3000 watts going to each one with no prob. I always say go more on power. 1992 Mazda 323 http://www.stevemead...323-wall-build/
MistaCrownVic00 Posted May 19, 2012 Author Report Posted May 19, 2012 Okay sounds good. I've seen a few Incriminators but not many and I see the aq3500 a lot. So having said more power is better I can't go wrong if I was to get 2 aq3500s (1 per sub)?
varietyguy Posted May 19, 2012 Report Posted May 19, 2012 That sounds like an excellent plan. I metered a 150.2 on the dash with 2 sundown 3000d's on 2 Mayhem 15's. 153.8 in the kick. 1992 Mazda 323 http://www.stevemead...323-wall-build/
MistaCrownVic00 Posted May 19, 2012 Author Report Posted May 19, 2012 Wow those are some high numbers well I'm going to go ahead and get those ordered and go from there. What electrical setup were you using with the 2 sundowns and mayhems?
varietyguy Posted May 19, 2012 Report Posted May 19, 2012 2 stock alts, 2 Kinetik 2400's and a 2000. but I still needed a ton more electrical and suggest you run more. Build log is in my sig and videos are on page 3. With 2 3500 your going to be pulling around 500 amps off of your electrical system. Definitely look into a high output alt and multiple batts. 1992 Mazda 323 http://www.stevemead...323-wall-build/
MistaCrownVic00 Posted May 19, 2012 Author Report Posted May 19, 2012 Okay one last question (I think) lol is there a place that you recommend that I go to for the batts and alt?
varietyguy Posted May 19, 2012 Report Posted May 19, 2012 Start by checking out the ads on the main forum page. A lot of vendors sell batts here. 1992 Mazda 323 http://www.stevemead...323-wall-build/
