Pvc Port Help
thacarter546
Im trying to design a box that fits in my truck more comfortable. I have a tc-3000 15" run off a A3000db in a 97 s10 xcab. I think i could fit a box with the sub facing forward and external pvc ports (dont have the money for aeros yet) at the very rear of the box facing towards the roof.
Right now i have a slot ported box facing forward right now and my passenger seat is not very usable.
I heard that lack of space can be made by using lots of port area? Is this valid only in spl applications?
I was hoping to use about 3 cubes for this box. and 4 inch pvc ports 3 possibly four, but i need to keep the length down so they dont cover my rear window up.
Is this a good or bad idea? would someone be willing to help me if i go get my measurements?
give me measurments, and ill see what i can do
u'd need at least three if not four ports, which means they will be long too
but id be glad, whats ur max dimensions
I can go to about 16" deep i can go 18-20" high to make room for the external ports the ports cant go over about 32-36 inches high. and for width i got about 32 inches (if i can relocate my batteries then i got more width
idk, its hard to attach the pvc to wood, you have to have a perfect circle, and then glue/screw them in... personally i think another slot port would be better in a truck with sub up, port up, well at least port up.
it gives you more airspace to work with and better air movement
if ur going to use pvc
3cuft with (4)3" pvc each 22.5" in length @ 32hz 28sqin port
3cuft with (3)4" pvc each 30" in length @32hz 37sqin port
3cuft with (4)4" pvc each 41" in length @ 32hz 50sqin port
  • Who's Online   0 Members, 0 Anonymous, 1382 Guests (See full list)
