sbg Posted May 29, 2012 Report Posted May 29, 2012 (edited) j/w if someone out there use's this amp , or what people think of it. out with a planet audio AP1500D and in with the precision power 2000.1 sedona. i run 2 RE audio RSX 1st gen's 12s that are dvc 2's so so i want to pick up the 550W RMS more out of this PPI then the planet audio @ 2ohm. Edited May 29, 2012 by sbg Quote 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
Guest Posted May 29, 2012 Report Posted May 29, 2012 (edited) edit: nevermind. googled edit 2: that planet audio amp will do what it says (rms rating, which is surprising). precision power is known to be pretty good, from what i've heard. Edited May 29, 2012 by Kranny Quote
sbg Posted May 29, 2012 Author Report Posted May 29, 2012 Quote 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
sbg Posted May 29, 2012 Author Report Posted May 29, 2012 got the new amp today came with a run of 1/0 lanzar wire 150 anl fuse/holed and set of monster rca cable two run 2 amps off 1 line. for $155 and the guy delivered to me from 150 mile away lol . Quote 01 focus se 110 amp alt Big 3 sky high and stinger hpm ofc 1/0 Super start platinum AGM (starting) 2 runs of 1/0 Execution audio front to back Kenwood double DIN DDx271 A pillars- orion 4" super tweeter and 2-1" alpines. Orion xtx 64 in the front doors 2:1 4th order bandpass Sealed off trunk Digital designs deadener on roof/ rear deck Orion hcca 12s (black coils) Orion xtr3700.1 Orion xtr250.2 mid/highs All sky high 1/0 in trunk dual runs(power/ground) Sky high dual 1/0 inputs 2 xs power D3100 in back Sky high batt blocks Rose audio batt blocks Stinger volt meter All sky high 1\0 fuse and holders Db link remote/ rca
