volvo 245 |Digital Designs| 4x18" | 161,07dB @Kick 158,5 @28Hz @headrest, 159,84 @windshield
Some testing before new ports.
Going to test 4 different port:
Now i have:
A=2152cm2 fb=44Hz d=17,2l l=8cm 159,15dB
New:
A=3375cm2 fb=53,9Hz d=27l l=8cm
A=2712cm2 fb=44Hz d=57l l=21cm
A=1518cm2 fb=38Hz d=12,1l l=8cm
A=2500cm2 fb=50Hz d=20l l=8cm
Nice!
I'd vote to change the 3375 to 44hz. Is that possible?
Not possible, i would have to move the first 2 subs roughly 10cms to back to make the port fit.
The 3375 is the "biggest" port and lowest tuning i can get without more modifications.
12063828_880032282073527_572223581971332
First port ready for testing!
I am propably sanding and taping some corners and windows tomorrow so i can get as close to 160 as i can...
At this point it is gettin cold and dark here in Finland, so i do not have much time to work with my car before i need to stop working on it.
I do not have big enough garage to get my car in, so all the work i do i do them outside.
I will test burp this tomorrow with 1ohm. If i get atleast 156,5 in the kick, i should be able to hit the 160 when i lower the ohms to .25.
Wish me luck!
And make sure you vote for the coolest volvo on SOTM ;)
Link to the voting:
http://www.stevemead...man-alternator/
I was really bummed when I didn't see db readings on all the ports. I'm sure you know this but don't forget to do sweeps. Your peak may change. I sometimes get excited and forget the little things lol.
Surely you are close enough to a 60 all you need is a couple more stickers and another coat of paint lol.
Good luck!
