volvo 245 |Digital Designs| 4x18" | 161,07dB @Kick 158,5 @28Hz @headrest, 159,84 @windshield
im remaking my build.
old had so many different setups and random stuff.
about me:
im 25yr old IT student, who builds an old volvo as an hobby on his spare time, budget is slim to none, but that does not necessary mean nothing. just means that every step has to be thought several times and need alot of work to save money for the pieces.
about car:
i'ts a volvo 245, B200F, 5speed manual. and it has a wall innit.
First Exterior:
Car looked like this back in summer 2011.
Pretty fast after getting it i tinted the backwindows.
then i got rid off the VOLVO -sign infront.
Finally i reheated the front bumper, bought bright turning signal covers.
added alot of stickers ofc. MAXBOOM -The Loud Side Of Life- :)
then the interior:
2011 summer's first setup was CRUNCH FATBOII with some shitty amp :D
then it was Autostudio REF UNL 18" with Focus acoustics 1500D, 193l box 30Hz tuned.
i played 147,98dB peak 144,2dB AVG with MaxBoom contest -song.
Spring 2012 i built first wall.
It was 6th order with 330l back (30Hz tune) 170l front (45Hz tune).
i played 144.22dB peak, 142,9dB AVG (MB song)
Last one was 4th order with same box as the 6th order.
I played 144.3dB peak @ 28Hz
it was pretty monstorous hairtricker.
but on AVG it hit like 120dB on MB song. so it had to be a goner.
then when summer 2012 started, i ripped the 4th order off and started to build another wall.
First i made a skeleton around.
more skeleton
me building more and more
floor
first plywood screwing in!
floor goin in
first ply at the back. small holes, but got filled up :)
made some sealers to the sides, not sealing 100% but it's a start
backside.
inside got doublesealed. still needs bracing and alot of stuff.
that's the thickness now. 36mm. i will do triangle pieces to the corners to seal em completely, and planning on fiberglassing the whole inside someday.
then i started to make the doors
i use old panels from old doors so it will be sealed at the window
both doors just before the fabric
thick fleece + first layer of resin
two layers resin on top, one inside + some fiberglass. i need to break the bracing from inside and fully fiberglass the inside.
but i am running on very low on cash, so ill start doing the wall before i can finish doors.
sofar so good, let me know your thoughts.
  • 1 month later...
long time no see, first sounds are out!
doors had fiberglass and stuff innit
installed electric windows to the front also.
amps for doors only, blaupunkt to highs, alpine to 10" bass and 6,5" coaxials on doors
last but not least i participated in Karhu Cruising event where i burp'd 147,6dB with roughly 1000w rms
my meters calc'd that i had 800w power at burp.
  • 4 weeks later...
Def looks good, lots of work for sure!
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
  • 5 months later...
