Well that's what I'm wondering, if there's a way to look at the amp specs or the watts and figure out how much you will need. The amp in question is a DC 5.0k
You bought a very very nice amp and dont even know the specs of it?? http://www.dcsoundlab.com/5k.html scroll down. the website lists them . . .
they even give you a recomendation of what you should run!!! common man
I haven't bought it yet. I know they give recommendations, but my mindset no matter what is research research research! I could easily look at the specs and everything on the site and assume that's that but I'm just not that comfortable.
I'm wondering, how do you know how much battery/alt power (amps or ah) you need to sufficiently supply a certain amplifier?
I'm actually uploading a video on youtube that will explain this.
XS Power gives a good wattage rating on their batts. You can use that as a guide and figure the alternator size required by the batteries you need to charge. Though you may be limited on alt size.
General idea is that the MAX amps of a batt can translate to it's wattage capabilities. At least in a short time frame. It will be important to have a proper alt to keep that battery charged as the amplifiers are draining them.
Example, a XS Power D3100 has a max amperage rating of 5000A. This is a short burst rating.
XS Power rates it at 5000w capability. Notice this is NOT amperage times voltage.
This is based off of a longer period of load time.
If you take into account amplifier efficiency and other losses in the system. You can get a realistic 4200w with that battery while playing music for a long period of time with amplifiers that are 85% efficient.
Now, you will need an alternator of at least 120a to feed that battery to a charge ratio of 1:1. This is approx how many minutes of charge it will take to top off the battery after that many minutes of full power play. So play at full tilt for 1 minute and it will need 1 minute to top off. Of course with 4200w you can play for several minutes.
These numbers in the example are just figures based on my own calculations and would be a bit lower if you are also using that battery to run the engine.
Thanks man. This helps a lot!
thought you bought it lol. as love as you got hte electrical to support it itll put that power out like it says. . .(i know the thread is about what you need anyways lol) like i said thought you bought it and didnt know haha
  • Who's Online   0 Members, 0 Anonymous, 1371 Guests (See full list)
