juancolchado Posted June 10, 2012 Report Posted June 10, 2012 swapped out my old 200amp alty with a new EA 300amp alty, need more WATTS, the postive post on the old alty had bad corrosion and fell off. i have two postive runs of 2/0 welders wire from the alty to the batts and one from the engine block to the neg on the batt, two more from the chasis to the neg on the batts. before i changed the alty i cleaned the lugs from the wire and charged up my two batts in the trunk. as soon as the batts were all charged up and my alty was swapped i cranked the car up and it was awesome, 14.5v but then i noticed after a while the voltage went down to 13.2v after about 45min. to an hour of the car being on. when i rev the car up it goes up to 14.6v but then back to 13.2v is this normal being its a bigger alty and the weather was 90degrees at 8pm? the car is a chrysler 300 2006 v6. thanks. -juan
juancolchado Posted June 10, 2012 Author Report Posted June 10, 2012 thanks to everyone that helped,went outside today cranked it up and the voltage was sittin nicely at 14.7v for about 5min.
kandiman71874 Posted June 10, 2012 Report Posted June 10, 2012 Sounds like typical over wound stock case low idle output to me when warmed up. There's a reason that the alt companies that wont stay with the times are falling behind in the game. EA is one of them Daily Driver 1999 Kia Sephia Kenwood DNX-893s Audison Bit One Processor 2 Dat 4.125's Sundown Audio SCV-6k Hertz hsk-165xl's Mids running active Focal V30 Series Tweeters running active Sundown Sa-8 v1's in the doors 2 Sundown Zv5 12's Lots of Hushmat Big 3+ and 3 + & 3- runs of Trystar 2/0 2 Dc Power Engineering 320 HP Alts 2017 Comp Vehicle 2006 Toyota 4 Runner Kenwood Excelon DNX-893s Audison Bit One HD DSP 4 Sundown Sa 6.5v2 Component Sets Focal Access 6.5 2 ways Sundown Audio Sax-50.4 Sundown Audio Sax-100.4 2 Dc Power 370xp Northstar agm27f Northstar agm65 2 Northstar asmagm 480's 2 Dual 1 Sundown Nightshade v3 12's 2 Sundown SCV-7500's All SMD Fuse Holders Shitload Of Sundown 1/0 120 sq ft Second Skin Damp Pro No, Its Not A Burp Truck!!!! 2016 Season 3rd place in Xtreme 1 At Finals 2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations) 2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL David said: audio is a lifestyle, not a hobby newls1 I cant read a tape to save my life... 1/2's are ok, but other marks confuse me kingsuv only men who cant read a tape, take it in the ass kingsuv you sir, get a pink hard hat on jobsites
