Guest Posted June 15, 2012 Report Share Posted June 15, 2012 where is the amp grounded to. does the metal where the wire lug is bolted to have all the paint sanded off so that its nice and shiny? where did you get it used from? Quote Link to comment Share on other sites More sharing options...
ShockStruck Posted June 15, 2012 Author Report Share Posted June 15, 2012 where is the amp grounded to. does the metal where the wire lug is bolted to have all the paint sanded off so that its nice and shiny? where did you get it used from? The amp is grounded to the trunk body, paint is sanded completely. I traded some guy on craigslist for it. The amp has never went into protection mode and appears cosmetically in good condition, although, the guy that sold it to me said that he blew a pair of 6x9's with it Quote Link to comment Share on other sites More sharing options...
Guest Posted June 15, 2012 Report Share Posted June 15, 2012 trunk body? like the side of the trunk or the floor? that doesnt really appear to be a good ground to be honest. class ab amps always run hot. as long as it doesn't go into protect i dont really see a problem with the temperature. do you have the mid or high settings on the eq on your headunit up at all? Quote Link to comment Share on other sites More sharing options...
pimpnFosgates Posted June 15, 2012 Report Share Posted June 15, 2012 is it really bolted or self tap scrrewed? Quote Lucky Durango Sony hu 4 croosfire 6.5mids crossfire 600.1 mono amp American bass 1280.4 mids and highs amp aq hdc3 12 2.4 cube net box, tuned to 34 and 14.4 inches of port per cube Link to comment Share on other sites More sharing options...
ShockStruck Posted June 15, 2012 Author Report Share Posted June 15, 2012 trunk body? like the side of the trunk or the floor? that doesnt really appear to be a good ground to be honest. class ab amps always run hot. as long as it doesn't go into protect i dont really see a problem with the temperature. do you have the mid or high settings on the eq on your headunit up at all? Everything on the headunit is 0 and the internal amplifier is disabled Amp is grounded to the side of the trunk but since that isn't a very good ground, where do you suggest I ground it? The amp if currently mounted on the back of my rear seats so I'd like to ground it somewhere in that area Quote Link to comment Share on other sites More sharing options...
ShockStruck Posted June 15, 2012 Author Report Share Posted June 15, 2012 is it really bolted or self tap scrrewed? Bolted, although I have heard that using self tap screwsis much better Quote Link to comment Share on other sites More sharing options...
Guest Posted June 15, 2012 Report Share Posted June 15, 2012 (edited) rear strut tower bolt will work great. does the amp get good ventilation being mounted on the back seats? edit: no, self tapping screws arent better. bolting is best. Edited June 15, 2012 by Kranny Quote Link to comment Share on other sites More sharing options...
