For your substage i guess you this Skaroffer http://www.stevemead...-42999-shipped/ + AQ 1200 http://www.audioque....ifiers_c_7.html + 2 of those batts one up front one in the trunk http://www.remybatte...tery-P9239.aspx, if you have a AGM batt up front only one for the trunk. Here is a terreble low offer of 0/! gauge wire http://www.audiosavi...0G100-BLUE.aspx buy it two times so you have enough for http://www.stevemead...big-3-tutorial/ or 3 times if you want to ground your amp´s on the front batt (best ground).
Other Amp option is a used DC 1.2 K out of this http://www.stevemead...-dc-audio-12ks/.
And how many 6x9 do you want 2 or 4?
I only need 2 6x9's :)
Insert signature here.
You don't need 6x9s. Get some 6.5s
Alright, ill get some 6.5s instead, i dont really know the difference tho, except the shape ans size :S
Are they for the door´s or for the rear?
Wa planning to put them in the rear, aint any places to put the speakers in the doors, but might be able to fit some in the dash.
get something like these to get some speakers in your doors , you could also make something like these with fiberglass . door speakers much better than rear speakers .
http://www.ebay.com/itm/6-1-2-Component-Speakers-Custom-Car-Enclosure-Pod-Mount-/261045764036?pt=US_Speaker_Sub_Enclosures&hash=item3cc78a3fc4#ht_3569wt_905
its not hard to get loud on "cheap". i have a alpine hu two DD 510's audiopipe amp alpine 6.5's power acustik amp and soundquest 1/0 wiring. that cost me 700 dollars. a lil more for the box and i put it in myself. thats loud to me and im happy with it. all on stock electical and at full tilt i drop down to 12 volts at most
Edited by Troy Smith
2004 cavalier 2 door 5 speedalpine cda-103skar pax 6.5s
power acoustik D1-6000power acoustic 4-2600soundquest 1/0 throughoutDC XL M2 18 walledstock altbig 3 donestock battery under hood, 1400cca 400ah semi battery in the trunk
  • Who's Online   1 Member, 0 Anonymous, 1379 Guests (See full list)
