Jessica Posted July 5, 2012 Report Share Posted July 5, 2012 I guess you could start by checking that voltage regulator, What is the normal charging voltage? Also, does it drop voltage right after it shifts gears? If it does then it might just be a bad connection. Just some ideas. it rest at 15.0 when it works but it drops voltage under acceleration So does it do it when you just rev the engine when it's in park/neutral? If it only does it in gear i would look real close at connections because your engine will twist a bit on the motor mounts and it may be pulling a wire causing a bad connection. Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
t-money Posted July 5, 2012 Author Report Share Posted July 5, 2012 well i just checked out my harness. nothing broken or messed up. no resistors even Quote 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056 Link to comment Share on other sites More sharing options...
t-money Posted July 5, 2012 Author Report Share Posted July 5, 2012 no i can push in the clutch and rev it and it will drop if i rev fast. but if i gradually bring it up the rpm range it wont fall out Quote 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056 Link to comment Share on other sites More sharing options...
MECHMAN Posted July 14, 2012 Report Share Posted July 14, 2012 no i can push in the clutch and rev it and it will drop if i rev fast. but if i gradually bring it up the rpm range it wont fall out It seems like you have checked everything that you can on the vehicle. My only sugestion would be to send the unit in to us so we can check it out. If there is anything wrong with the unit, we will fix it and repair it under warranty. Matt Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
