2003 Grand Cherokee Build
More work done today.
Started with factory CD Changer which I did not use.
Making an amp rack for my DD M2A. Only using scraps from around the shop. Started with sides.
Made a notch to pass by a factory screw.
Connecting brace board
Cut here.
Had to extend the notch for clearance.
louisiana :)
Layout of vent holes
Drill press
One big hole for possible fan in the future
A little paint and mounted
Screwed amp down, side view
Wheel well clear.
Welding cable and heat shrink on remote wire. All black look
More when it happens
louisiana :)
solid build right here ! like it ! Jeep Cherokee's FTW ! following this ^^^
Thanks! Suuper slow build but, I would rather do it right and not rush. Going to start the new box within the next week hopefully.
louisiana :)
  • 4 weeks later...
So I added two more runs of 1/0. One will serve as ground from front battery to the rear battery.
Got some more welding cable.
Going in here
Push...Pull
Tight under there.
To the back
Here is where the runs end. Im putting a battery right under the amp.
louisiana :)
I have had my alternator installed for a while. Though I will send it back in eventually for modification.
Wiring before with big 2.
After Still just big 2.
Will pick up some black straps soon. And do a little trick.
Also I got a Kinetik HC1800 to put in(no pictures yet). I will stick it under the amp. Have some more ring terminals coming. Once they come in I can fuse the two batterys together and finish the big 3 with fusing.
louisiana :)
