Those look eerily like the w3013ps subs they make but with a slightly different cone(<-edit). I mean the specs are almost identical. Hmm, I'm going to bet your best bet is either give them 2cuft each and tune really low or put them in a sealed box. Since they are so similar i would say they would probably do better sealed. Wire to 1ohm and put them on a skar1500.1 if they die just get something better.
Yeaa They Recommend Like 1.25cuft So Ill Prolly Go 1cuft And They Are Preferred Sealed Also... How Much Does The Skar Amp Go For???
try an 1800 watt kenwood
not the greatest brand, but i had 2 12" Alpine Type E's on it and it was totally fine
I can't believe you got away with a Kenwood 1800W amp on Type E's. I had a Fosgate P6001 on two of them and they would bottom out on THAT power. Also, Kenwood makes solid products all around, I certainly would not consider a Kenwood amp to be junk.
How Do You Feel About Their Subs? Average? I Never Heard Them Personally
well they're not junk, but they run kind of hot :P
yeah they were a little over powered lol
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
  • Who's Online   1 Member, 0 Anonymous, 658 Guests (See full list)
