locomanny569 Posted July 12, 2012 Author Report Share Posted July 12, 2012 does the second one have to be in the same CCA zone? Nope it could be a billion, doesn't matter lol really? so when i start the car it only start with the first one? Yes. Thats what a battery isolator does. Allows power into the battery (from the alt, thru the main, into the 2nd) but doesn't allow power to go from the 2nd to the main. ok this is were it gets messy when it come to batts because every one tells me i dont need a isolator is i wiring them parallel?? Quote My build http://www.stevemead...20#entry2018495 Car: 2003 Cadillac DTS (1) Hifonics Brutus BRZ2400.1 (1)Hifonics Zrx600.4 (1) 1000 watt crunch amp (1)200 watt boss amp (2) Pyramid TW46 (4) Infinity Kappa 60.9cs (1) EV 10 inch (2) XSpower 1200 (4) Pyramid TW18 box tuned at 32 Hz (2) DC level 3 Link to comment Share on other sites More sharing options...
andale927 Posted July 12, 2012 Report Share Posted July 12, 2012 does the second one have to be in the same CCA zone? Nope it could be a billion, doesn't matter lol really? so when i start the car it only start with the first one? Yes. Thats what a battery isolator does. Allows power into the battery (from the alt, thru the main, into the 2nd) but doesn't allow power to go from the 2nd to the main. ok this is were it gets messy when it come to batts because every one tells me i dont need a isolator is i wiring them parallel?? You definitely don;t need an isolator. Only time a battery isolator would help is if you were running a non agm battery up front. Quote Link to comment Share on other sites More sharing options...
locomanny569 Posted July 12, 2012 Author Report Share Posted July 12, 2012 ok just one more last time so if i have a 800 CCA batt in front i could put any CCA batt in the rear with out a isolator or do i need the same CCA as the front which i might just do.. Quote My build http://www.stevemead...20#entry2018495 Car: 2003 Cadillac DTS (1) Hifonics Brutus BRZ2400.1 (1)Hifonics Zrx600.4 (1) 1000 watt crunch amp (1)200 watt boss amp (2) Pyramid TW46 (4) Infinity Kappa 60.9cs (1) EV 10 inch (2) XSpower 1200 (4) Pyramid TW18 box tuned at 32 Hz (2) DC level 3 Link to comment Share on other sites More sharing options...
CleanSierra Posted July 12, 2012 Report Share Posted July 12, 2012 CCA has nothing to do with multiple battery set ups. The only reason you would run an isolator is if you were gonna play with the car OFF and wanted the system to NOT pull from the starting battery so you could START the car after playing with the car off. ORRR, if you were running a flooded lead acid battery along with an AGM battery. Just get a battery that FITS your battery tray, and satifies the cranking amps required of your Caddy. Its that simple dude. Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
locomanny569 Posted July 12, 2012 Author Report Share Posted July 12, 2012 CCA has nothing to do with multiple battery set ups. The only reason you would run an isolator is if you were gonna play with the car OFF and wanted the system to NOT pull from the starting battery so you could START the car after playing with the car off. ORRR, if you were running a flooded lead acid battery along with an AGM battery. Just get a battery that FITS your battery tray, and satifies the cranking amps required of your Caddy. Its that simple dude. ok thanks Quote My build http://www.stevemead...20#entry2018495 Car: 2003 Cadillac DTS (1) Hifonics Brutus BRZ2400.1 (1)Hifonics Zrx600.4 (1) 1000 watt crunch amp (1)200 watt boss amp (2) Pyramid TW46 (4) Infinity Kappa 60.9cs (1) EV 10 inch (2) XSpower 1200 (4) Pyramid TW18 box tuned at 32 Hz (2) DC level 3 Link to comment Share on other sites More sharing options...
