lotus Posted July 12, 2012 Report Share Posted July 12, 2012 I have a cobalt lt coupe and I wanna wire a deka 9a31 battery to the stock battery. How would i go about doing it or should I just switch the stock battery with the deka. All on stock alt and big 3 done. I have an American bass 100.1 1500rms amp. Quote 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH Link to comment Share on other sites More sharing options...
Guest Posted July 12, 2012 Report Share Posted July 12, 2012 either in parallel/with a relay/ or with an isolator those are your 3 options, be kareful so you dont blow out your altinator Quote Link to comment Share on other sites More sharing options...
lotus Posted July 12, 2012 Author Report Share Posted July 12, 2012 where would i get an isolator? Quote 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH Link to comment Share on other sites More sharing options...
Guest Posted July 12, 2012 Report Share Posted July 12, 2012 A local audio store. This explains the 3 types. Quote Link to comment Share on other sites More sharing options...
lotus Posted July 12, 2012 Author Report Share Posted July 12, 2012 so I can parallel or relay a gel and agm batt together Quote 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH Link to comment Share on other sites More sharing options...
Avery Howell Posted July 12, 2012 Report Share Posted July 12, 2012 A local audio store. This explains the 3 types. EXO Rocks!!!!!!!!!!!!!! Quote 2012 Jeep Wrangler 3.6 W/ 6 Speed Build Log 2011 Ford F-150 SVT Raptor 6.2 Build Log YouTube Link to comment Share on other sites More sharing options...
Lbox88 Posted July 12, 2012 Report Share Posted July 12, 2012 Just wire the 2 batteries in parallel, + to +, - to -. Do not use an isolator. Make sure to fuse the + wire between the 2 batteries, putting a fuse within 18" of each battery. Quote UBL | Build Log Link to comment Share on other sites More sharing options...
lotus Posted July 12, 2012 Author Report Share Posted July 12, 2012 so gel and are compatable Quote 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH Link to comment Share on other sites More sharing options...
Lbox88 Posted July 12, 2012 Report Share Posted July 12, 2012 You should be fine. Quote UBL | Build Log Link to comment Share on other sites More sharing options...
lotus Posted July 12, 2012 Author Report Share Posted July 12, 2012 wat amp fuse should I use? Quote 2010 Cobalt LT Coupe Subs: 2 American bass XFL 12s Amp: Crescendo BC3500D Big 3 in 1/0awg 29hz box stinger volt meter 2nd battery Deka 9a31 pioneer DEH-9400BH Link to comment Share on other sites More sharing options...
