reg93f150 Posted July 12, 2012 Report Posted July 12, 2012 Demensions: ~63 inches long 9 inches at the bottom 3 inches at the top 25-30 tall ~60 inches long at the top of the box i dont know if i should do a sealed or a ported box with this, if yall have any ideas on what would sound the best id appreiciate it the subs are the new model kicker compvx12's dual 4 ohm not sure about the amp yet, was lookin at a mb quart onx1.1500 amp (still could use ideas about the amp) (budget is about $200) will add anything else yall need thanks so much for the help, it really is appreiciated more then yall think ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
reg93f150 Posted July 12, 2012 Author Report Posted July 12, 2012 Min Rec Sealed Box Volume (CU. FT., Liters) 1.0, 28.3 Max Rec Sealed Box Volume (CU. FT., Liters) 4.6, 130 Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6 Max Rec Vented Box Volume (CU. Ft., Liters)** 2.25, 63.7 are what the subs need and have a mounting depth of 6 6/11th inches thank yall again if yall are helping me ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
reg93f150 Posted July 13, 2012 Author Report Posted July 13, 2012 anyone got any ideas for 2 kicker compvx12 dual 4 ohm behind a single cab truck with the dimensions of ~63 inches long 9 inches at the bottom 4 inches at the top 25-30 tall ~60 inches long at the top of the box thanks for the help ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
