Srh_rider12 Posted July 14, 2012 Author Report Share Posted July 14, 2012 to be honest i dont know how to use torres and the port is 3in and is tuned to 42 htz Quote Build Log ----> http://www.stevemeadedesigns.com/board/topic/137987-04-chevy-silverado-build/page__fromsearch__1 Link to comment Share on other sites More sharing options...
Joe X Posted July 14, 2012 Report Share Posted July 14, 2012 Well no issues regarding your original question but the design is questionable which doesn't really mean it will sound bad but if you are using a 12" then the box is rather big wo it won't handle much power before bottoming out and you may experience cancellation but test it either way and if you find difficulties you might need considering a rebuild. Quote Link to comment Share on other sites More sharing options...
Srh_rider12 Posted July 14, 2012 Author Report Share Posted July 14, 2012 Well no issues regarding your original question but the design is questionable which doesn't really mean it will sound bad but if you are using a 12" then the box is rather big wo it won't handle much power before bottoming out and you may experience cancellation but test it either way and if you find difficulties you might need considering a rebuild. The box is too big? and ok it sounds really good and my amp really has trouble pushing it but i guess i will find out when i throw a AQ1200D at it. If it bottoms out then do i just shorten the length of the box? and thanks for all your input Quote Build Log ----> http://www.stevemeadedesigns.com/board/topic/137987-04-chevy-silverado-build/page__fromsearch__1 Link to comment Share on other sites More sharing options...
