Leboy23 Posted July 14, 2012 Author Report Share Posted July 14, 2012 my bad guys. It is a 12" thought i put that you did. people just can't read properly. where? I didn't at first. I had to edit it Quote 2012 Nissan Altima SL DC M2 Lvl 3 12" with AR cone DC 1.2K Amp Kicker Sum8 Kicker 4 Gauge amp kit XS Power D2700 1.5 Cubic ft net tuned to 38Hz Link to comment Share on other sites More sharing options...
Joe X Posted July 14, 2012 Report Share Posted July 14, 2012 (edited) Here is a suggestion, let me know if you need anything changed: Enclosure Specifications: Fb = 34 Hz Vb = 1.75 ft^3 External Height = 15 in External Width = 23.75 in External Depth = 16 in Port Width = 2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 23 3/4 x 15 Left & Right Sides = 13 3/4 x 13 1/2 Top & Bottom = 23 3/4 x 13 3/4 L Port Internal Assembly Parts: Front to Back = 11 3/4 x 13 1/2 Extension = 13 1/2 x 13 1/2 Generic dimensions assembly guide: Edited July 14, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
Radioactiv Posted July 14, 2012 Report Share Posted July 14, 2012 by no means am I a box designer but I thought it should have around 30 to 35" of port area. I cold be wrong though. That is where I was having my problem at. I would get enough port area but way to much port area per foot. Thanks John for your help. I'm gonna mess around some more also and see what I can come up with. May just have to start building boxes and see what sounds best He didnt use your max dims, im sure he could bump it up to 18-20sq in per cube. I went from 16 to 21 with my box, helped a ton. Quote 1993 Ford RangerWalkthrough20, North Georgia Link to comment Share on other sites More sharing options...
Leboy23 Posted July 14, 2012 Author Report Share Posted July 14, 2012 (edited) Here is a suggestion, let me know if you need anything changed: Enclosure Specifications: Fb = 34 Hz Vb = 1.75 ft^3 External Height = 15 in External Width = 23.75 in External Depth = 16 in Port Width = 2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 23 3/4 x 15 Left & Right Sides = 13 3/4 x 13 1/2 Top & Bottom = 23 3/4 x 13 3/4 L Port Internal Assembly Parts: Front to Back = 11 3/4 x 13 1/2 Extension = 13 1/2 x 13 1/2 Generic dimensions assembly guide: I think im going to try this out. It looks pretty good. Thanks for your time. I've been going crazy the last few days trying to figure something out with this box. Trying to get it built before the sub shows up next week so I can just throw it in. Edited July 14, 2012 by Leboy23 Quote 2012 Nissan Altima SL DC M2 Lvl 3 12" with AR cone DC 1.2K Amp Kicker Sum8 Kicker 4 Gauge amp kit XS Power D2700 1.5 Cubic ft net tuned to 38Hz Link to comment Share on other sites More sharing options...
