Could someone help with a box design?
my bad guys. It is a 12" thought i put that
you did. people just can't read properly.
where?
I didn't at first. I had to edit it
2012 Nissan Altima SL
DC M2 Lvl 3 12" with AR cone
DC 1.2K Amp
Kicker Sum8
Kicker 4 Gauge amp kit
XS Power D2700
1.5 Cubic ft net tuned to 38Hz
Here is a suggestion, let me know if you need anything changed:
Enclosure Specifications:
Fb = 34 Hz
Vb = 1.75 ft^3
External Height = 15 in
External Width = 23.75 in
External Depth = 16 in
Port Width = 2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 23 3/4 x 15
Left & Right Sides = 13 3/4 x 13 1/2
Top & Bottom = 23 3/4 x 13 3/4
L Port Internal Assembly Parts:
Front to Back = 11 3/4 x 13 1/2
Extension = 13 1/2 x 13 1/2
Generic dimensions assembly guide:
Edited by Joe X
by no means am I a box designer but I thought it should have around 30 to 35" of port area. I cold be wrong though. That is where I was having my problem at. I would get enough port area but way to much port area per foot. Thanks John for your help. I'm gonna mess around some more also and see what I can come up with. May just have to start building boxes and see what sounds best
He didnt use your max dims, im sure he could bump it up to 18-20sq in per cube. I went from 16 to 21 with my box, helped a ton.
1993 Ford Ranger
Walkthrough
20, North Georgia
Fb = 34 Hz
Vb = 1.75 ft^3
Port Width = 2 in
Cut Sheet List:
I think im going to try this out. It looks pretty good. Thanks for your time. I've been going crazy the last few days trying to figure something out with this box. Trying to get it built before the sub shows up next week so I can just throw it in. Edited by Leboy23
DC 1.2K Amp
Kicker Sum8
XS Power D2700
  • Who's Online   1 Member, 0 Anonymous, 390 Guests (See full list)
