codi Posted January 8, 2008 Report Posted January 8, 2008 heyy every one, i got a question for running your stereo in your house when its not in your car. my teacher has a supplier of many neat little gadgets and one happens to be 12 V power supplies, what type of amperage would i need to run it? if its just like one amp and one sub? just a wee bit lower then what my amp can take? if any one can help its would be very appreciated
MickyMcD Posted January 8, 2008 Report Posted January 8, 2008 It completely depends on what current rating your amplifier is. However, most 12v DC Lab power supplies only give 10-15 amperes DC. Most car audio amplifiers specify a 40-60 ampere input rating. Please check your amplifier's current draw then match that to the RMS output of a DC power supply. However, you will find it cheaper just to buy home audio/AC gear. Cheers, Mick Work;DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS VeniceMeyer Sound CQ-1's, CQ-2's, PSW-2'sRAMSA Monitor AmplifiersP.Audio MonitorsBSS OMNIDRIVE and SoundwebDBX 231 and Klark Teknik DN360 EQ'sRCF TT22ARCF ART320
kbreudi Posted January 8, 2008 Report Posted January 8, 2008 It completely depends on what current rating your amplifier is. However, most 12v DC Lab power supplies only give 10-15 amperes DC. Most car audio amplifiers specify a 40-60 ampere input rating. Please check your amplifier's current draw then match that to the RMS output of a DC power supply. However, you will find it cheaper just to buy home audio/AC gear.Cheers, Mick X2 There are some power suplies that are made for demoing 12v equipment that have a higher rating like 50 - 60 amps, but they are very expensive, could deff get a better home setup for the money....but on the other hand if you get the power supply for free and have a small amp that only draws about 15 amps, go for it TEAM SUNDOWN 4 Nightshade 15"s 2 Sundown SAZ-4500 8 Deep Cycle batts 1998 Cadillac Catera SPLMAX CUP 2008 Fourth Place Overall
codi Posted January 8, 2008 Author Report Posted January 8, 2008 ya i was just wondering because i can get the power supply for cheapish, my amp has 2 30A fuses so like a 75A one would do if its adjustable and what not? and if not some thing like a 50A would do
