caraudiolove Posted July 21, 2012 Report Posted July 21, 2012 i need help on a subwoofer box for 2 kicker comp 12" i need the subwoofer box to be efficient for daily and spl 30W,32L,16H
severancej Posted July 21, 2012 Report Posted July 21, 2012 what amplifier do you have and what vehicle is it in? Also what kind of music do you listen to and the specs for you subwoofer would be helpful. 98' dodge ram 140A alt Big 3 XS D2700 JVC kd-r310 Rockford T500-1BDCP 2 Sundown E12 Ported 4cubes 35hz Rockford P400-4 2 Infinity reference 3way 6x9 2 Polk DB 5 1/4 2x layer dynamat all doors
caraudiolove Posted July 21, 2012 Author Report Posted July 21, 2012 ma audio synergy 1600w 1999 monte carlo ls rap,country,rock Model C12D4 Size (IN.,CM) 12, 30.0 Impedance (OHMS) 4 DVC Max Rec Amplifier Power (WATTS PEAK/RMS)* 400/200 Sensitivity (dB 1w/1m) 88.3 Frequency Response (Hz) 27-500 Mounting Depth (IN.,CM) 5-7/8, 14.8 Mounting Cutout (IN.,CM) 11, 27.9 Min Rec Sealed Box Volume (CU. FT., Liters) 1.25, 35.4 Max Rec Sealed Box Volume (CU. FT., Liters) 3.5, 99.1 Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6 Max Rec Vented Box Volume (CU. Ft., Liters)** 2.25, 63.7
caraudiolove Posted July 21, 2012 Author Report Posted July 21, 2012 what does it mean by port bends? and i was looking at the manual and it said their the port area range had to be 70-100
caraudiolove Posted July 21, 2012 Author Report Posted July 21, 2012 could you draw it on google sketchup please
