Comparison of entry/medium level 12inch subs?
Im asking for a comparison of entry to medium level subs, off the same power, in the same setup.
nobody can tell you. what if the next step up needs more power to get going, could be less loud.
that question was much easier to understand too.
im thoroughly convinced you did not do a 146.6 with 2 entry level subs on 1.2k...no not sealed not on the TL. =/
are you Terry Brocks?
just out of curiosity, which amp was it. i read your build log and it showed you using a DD Z1 which certainly isnt a 1500 rms amp ahah
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Z1 was what I'd used on the two Elevation Audio subs, the Pioneers were being run off a ReSponse brand 1500watt.
ahhh well very good!! just to answer your question, most likely if you get a beefier sub on same power youd prolly be quieter because speaker wont displace as much air as the lower models which will be more efficient on less power than your big ones.
BMW M340 xDrive
The current setup I have, the Pioneers are getting about 800watts each, rated at 400. They'd have to be suffering pretty badly from power compression, which is why I'm hoping a higher powered, higher excursion woofer could still do similar numbers, off the same power.
  • Who's Online   0 Members, 0 Anonymous, 1883 Guests (See full list)
