FS: Dynaudio MD142s
What I have here is an amazing set of mid range speakers. Some of the clearest sound I have ever heard and they really screamed off my SAX-125.2.
Specs:
The Esotec MD 142 75mm (3-inch) diameter soft dome midrange features a large diameter aluminum voice coil with a centered magnet housed in a relatively compact and shallow enclosure.
MD 142 Soft Dome Midrange
Suspended in ferrofluid for controlled damping, an extremely light aluminium voice-coil drives the dome. Aluminium, due to its extremely low weight, allows a larger coil diameter and more windings at a lower mass as compared to conventional designs. The heat produced by the voice coil is dissipated to the magnet system with the help of ferrofluid cooling liquid.
The precisely optimized dome geometry and the low mass of the internal moving parts ensure a very transparent and detailed reproduction of all frequencies.
The Esotec MD 142 is housed in a compact self-contained enclosure with a vented pole piece and damped rear chamber. It includes an integrated protective grille, and requires no additional airspace for installation.
It thus may easily be integrated into a wide range of install applications and locations, including kickpanel, in-dash, in-door or rear deck mount placement. In tandem with the incredibly powerful Neodymium magnet, the sound reproduced by the MD 142 is smooth, detailed, dynamic and simply amazing.
  • Nominal long term IEC (Depending on crossover) 100 W
  • Transient (10 ms) 1000 W
  • Voice coil diameter dc 75 mm
  • Voice coil height hc 5.5 mm
  • Voice coil layers nc 2
  • Magnetic gap height hg 3 mm
  • Linear excursion, peak to peak 2.5 mm
  • Max. excursion, peak to peak 5 mm
  • Magnet weight wm 0.24 kg
  • Nominal impedance Znom 8 O
  • DC resistance Re 5.3 O
  • Voice coil inductance Le mH
  • Resonance frequency fs 475 Hz
  • Recommended frequency range 700 - 6000 Hz
  • Net weight 0.75 kg
  • Overall dimension ø 121 x 66 mm
$300 for the pair...NO TRADES
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
price?
Edit: Nvm you updated it.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
can i get a couple better pics?
If you can wait until tomorrow I can get you better pics....I have to take them out of my truck to do so.
www.4xspower.com
bump it up.....didnt get a chance to take more pics tonight.....working like crazy
www.4xspower.com
TTT.....still gotta get some better pics but is there any interest?
www.4xspower.com
Still for sale
Here are a couple other pics
www.4xspower.com
Still for sale
www.4xspower.com
Bump this...still for sale
www.4xspower.com
