So I hadn't been in my car for about 5 hours and I had my back seats down to make it louder and I looked back and the illuminated Anarchy was flickering and eventually turned off. It feels really hot. But this has never happened before. Well, it is about 92 degrees out right now and my garage is a lil warmer than that. Is that why it was flickering? Due to heat?
___________________________________________________________________________________
-1997 Oldsmobile Cutlass Supreme Coupe-
-2 12'' Alpine Type R's-
-Sony xPlode Head Unit-
-Planet Audio AC2000.2 Amplifier-
Anarchy Series 2-Channel Amplifier
RMS Power Rating
2 ohms: 700 Watts x 2 chan.
Bridged, 4 ohms: 1400 watts x 1 chan.
Yeah man.. Hot weather fucks with everything. It should be okay..assuming it's just hot. Maybe install a couple small fans around your amp if possible
The amp is probably just hot. What load are you running ?
http://www.youtube.com/watch?v=CSsWY57oM4Q
It's 4 ohms at 1400 watts rms, yes I know I am not get all of that. And ill have to check it tonight to see if it is still doing it.
I probably should put a couple of fans next to it, good idea.
RMS Power Rating
My amp is completely cool right now. It's only 78 degrees out and it is still doing it. Any suggestions?
RMS Power Rating
check all power/ground connections. at the fuse block, at the battery, at the ground point (which is hopefully actual metal like a strut tower, and not a seat belt bolt or the rear deck)
edit: dont just look at the connections. tug or wiggle a little. anything that moves, re-tighten it snug
Edited by Kranny
i think it's something with those amps, my cuzin had (2) 5000's and one (blue light) went out and he had (3 or 4) ac2400's and all those lights went out sohe sold every one of them. he then went with (2) lanzar optidrive 5000 (i think) with the optidrive 4 channels, they didnt have the power he wanted. my audiopie 1500 made his 15's harder. than the lanzars. finally he sent them back, got a credit and got (2) audiopipe ap3000.1d, 1 to each lanzar 1533d and (5) audiopipe ap2004 for his highs and mids
2006 Suzuki Hayabusa GSX1300R Limited Edition
2006 Dodge Charger SXT
Kenwood Excelon KDC - X692
Factory Boston Acustics System upgrade (7 speaker system)
2010 Chevy Tahoe LS
Pioneer AVIC - Z130
Audiopipe AP-2004
Audiopipe AP-15001D
(2 pair) Boston Acoustics PRO60SE 6.5 - changed to Polk Audio MM6501
(2) Planet Audio BB215D - changed to Lanzar Opit 1533d for now FREEBIES
  • Who's Online   1 Member, 0 Anonymous, 1218 Guests (See full list)
