rbly1025 Posted August 6, 2012 Report Share Posted August 6, 2012 (edited) Max dimensions: Height- 20" Width- 12 Depth- 14" Wanting it to be tuned around 30 hrtz Edited August 6, 2012 by rbly1025 Quote Link to comment Share on other sites More sharing options...
hook'em Posted August 6, 2012 Report Share Posted August 6, 2012 That is definitely not going to work. WIth that box design your box is tuned to about 77Hz and will sound like complete crap. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 6, 2012 Report Share Posted August 6, 2012 That is definitely not going to work. WIth that box design your box is tuned to about 77Hz and will sound like complete crap. huh? how did you get a tuning when he just posted external dimensions? OP, you dont want to tune a DD woofer that low. stick with around like 35-37hz. Quote Link to comment Share on other sites More sharing options...
ZachG Posted August 6, 2012 Report Share Posted August 6, 2012 That is definitely not going to work. WIth that box design your box is tuned to about 77Hz and will sound like complete crap. Can you explain how you got that with just his max dimensions? Quote 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad) Link to comment Share on other sites More sharing options...
Joe X Posted August 6, 2012 Report Share Posted August 6, 2012 Welcome to the forums.Here is a suggestion for a box: Enclosure Specifications: Fb = 37 Hz Vb = 0.88 ft^3 External Height = 12 in External Width = 20 in External Depth = 14 in Port Width = 1 5/8 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 17 5/8 x 10 1/2 Back = 20 x 10 1/2 Left & Right Sides: Side 1 = 12 1/2 x 10 1/2 Side 2 = 13 1/4 x 10 1/2 Top & Bottom = 20 x 14 L Port Internal Assembly Parts: Front to Back = 10 7/8 x 10 1/2 Extension = 14 1/2 x 10 1/2 Extension 2 = 3 1/16 x 10 1/2 Let me know any questions. Quote Link to comment Share on other sites More sharing options...
hook'em Posted August 6, 2012 Report Share Posted August 6, 2012 Its a simple algebra equation. Quote Link to comment Share on other sites More sharing options...
xx1 Posted August 6, 2012 Report Share Posted August 6, 2012 That is definitely not going to work. WIth that box design your box is tuned to about 77Hz and will sound like complete crap. Can you explain how you got that with just his max dimensions? X2 Welcome to the forums.Here is a suggestion for a box: Enclosure Specifications: Fb = 37 Hz Vb = 0.88 ft^3 External Height = 12 in External Width = 20 in External Depth = 14 in Port Width = 1 5/8 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front = 17 5/8 x 10 1/2 Back = 20 x 10 1/2 Left & Right Sides: Side 1 = 12 1/2 x 10 1/2 Side 2 = 13 1/4 x 10 1/2 Top & Bottom = 20 x 14 L Port Internal Assembly Parts: Front to Back = 10 7/8 x 10 1/2 Extension = 14 1/2 x 10 1/2 Extension 2 = 3 1/16 x 10 1/2 Let me know any questions. that's a great looking option right there... Quote audio related merchandise (decals,banners,lanyards,hats,shirt,etc) Link to comment Share on other sites More sharing options...
xx1 Posted August 6, 2012 Report Share Posted August 6, 2012 Its a simple algebra equation. can you post the magical equation so we can all learn.. Quote audio related merchandise (decals,banners,lanyards,hats,shirt,etc) Link to comment Share on other sites More sharing options...
ZachG Posted August 7, 2012 Report Share Posted August 7, 2012 Its a simple algebra equation. I would love to learn this equation, please post a link or something. This is ground breaking Quote 1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad) Link to comment Share on other sites More sharing options...
rbly1025 Posted August 7, 2012 Author Report Share Posted August 7, 2012 Thanks a lot for the design I'll look into drawing it up later this week! Quote Link to comment Share on other sites More sharing options...
