99blazer Posted August 6, 2012 Report Posted August 6, 2012 I got a couple of questions. my first question is i got a terrible whining noise in my speakers. Ive got my door speakers running on a 4 channel amp. ive googled it and ive tryed many different things like moving the amp ground and unplugging and plugging the rcas. Any ideas on this one? second is i got an extra battery i wanted to put in my truck. im running 4 DDs at 1ohm and my sub amp shuts off when i play it hard and then i get this bad crackling sound in my door speakers. which im taking is from the battery losing power. ive done the big 3 and i upgraded the alternator to a 140amp. and i wanted to know if adding a battery if it would keep the amp running at 1ohm. any help would be awsome 08 Ford F150
Guest Posted August 6, 2012 Report Posted August 6, 2012 are you playing at idle when the amp shuts off?
99blazer Posted August 6, 2012 Author Report Posted August 6, 2012 when i stop at stop lights and stuff i turn the subs down but it will shut off while im driving 08 Ford F150
fecupe2001 Posted August 6, 2012 Report Posted August 6, 2012 what amplifier is that? second battery ALWAYS helps! I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
99blazer Posted August 7, 2012 Author Report Posted August 7, 2012 its a soundstream 1600.1D and i also got a 640watt 4-channel. i got 1/0 running to the 1600 and 4gauge running to the 4 channel im using a yellow top and a 140 amp alt. 08 Ford F150
