used in this install.......
24" Lexani Roma on 305/35/24" Kumho Tires (installed previously by owner)
Stock Navigator Touchscreen deck (built in Navigation, etc.)
JL Audio Clean Sweep Processor
Apple Ipod Ready (and being used)
Nav-Tv Module  to make the stock screen into a Monitor
4 10.2" Savv Headrest monitors(2)with Side loading DVD players
(4) Savv Personal Headphones (wireless, one for each screen)
Rockford Fosgate T3000.1 Sub amp
Rockford Fosgate T4004 Mids/highs
(2) RE MT 12's (Resonant Engineering)
(1) Set MBQuart 6 ½” Premium Componants (front)
(1) Set MBQuart 5 ¼” Premium Componants (rear)
Fiberglass, Plexiglass Ported "Meadebox" with custom LED Endlit “Lincoln” Logo (RGB style, ALL colors available at the touch of a button)
Box wrapped in Fine Italian Leather with French Seams to match stock interior
Custom in dash mounted Rockford Fosgate bass level, frequency and JL Audio master Volume knob( to match stock interior)
Rockford Fosgate 12ga Speaker Wire
250amp Iraggi alternator
150 feet Stinger 1/0 cable (every connection Soldered to Stinger Terminals)
Stinger Helix Series Interconnects
Stinger Distribution Blocks
Stinger Road Kill Sound Deadening
300Amp Fuse
Odyssey pc2150 Battery
Lincoln Navigator Upper/Lower Vertical Billet Grilles
This wont be a crazy install at all, should sound nice, get loud if needed, and be nice and classy.  Everything is behind the third row so i dont have alot of space but i think i have just enough........
    Posted Image
    Posted Image
    Posted Image
    Posted Image
Follow my Tweet (Twitter)
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
  Posted Image
  Posted Image
  Posted Image
  Posted Image
2 4" Aeroports will be molded into the top with the fiberglass so it will all flow like its "one" rather than seeing ****ty screws holding the ports to the box.  This is very rough, gimme time  ;)
some of it is particle board- some of it is MDF.......but the thing is, im using ALOT of fiberglass so it dont really matter.
Posted Image
Ran out of fiberglass matt and had to go to my emergency stash....no worrys, ill re-up my supply tonite at least this crap-mat will keep me working.
Look it even gave me "hairy palms"  :D
  Posted Image
Ill end up 45-ing as many 90's as i can get to.....the ol' resin in the corner trick works great.
Posted Image
Posted Image
Posted Image
Time to go over the top with Kitty Hair to make it a little bit stronger and to build up some spots that needed it.
  Posted Image
  Posted Image
The part everyone hates, time to sand.....
  Posted Image
  Posted Image
  Posted Image
  Posted Image
  Posted Image
the stuff i use is called "Nytex X-Mat"  It is half "heavy chopped" and half "weaved" i guess you could say.  Heres some pics of it.
Posted Image
Posted Image
Notice a piece from my "emergancy stash"....its so thin you can see right thru it.  The Nytex is so thick when you bend it, it stays, the cheap stuff just flopps back over.
Posted Image
The "chemist" is in the house.....this bottle with the little measuring cup on top is like the greatest thing ever invented.  For the MEKP, I dont go by "drops" anymore, im all about the "CC's"  ;)
Posted Image
Posted Image
Posted Image
Posted Image
looks like the same pics, but really its progress  :)  I took it "easy" last nite and only worked a couple hours on it after i got home from my regular job (at 5).  Im starting to feel confident this box would stop a bullet....its so strong now.  :)    My next mission is to make it pretty and prepping the built in amp rack for some wires.
Posted Image
Posted Image
Posted Image
Posted Image
Any doubts on the integrity of this box?  :D
Ill probably end up coating the inside with something to smooth it up some and not have that ugly fiberglass look.  Im thinking of a plexi window in it so of course it cant look like crap on the inside.
time for filling and sanding......
almost starting to take shape
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
  • Who's Online   1 Member, 1 Anonymous, 1677 Guests (See full list)
