seaudio Posted August 7, 2012 Author Report Share Posted August 7, 2012 oooooohhhhhhh ok. let me chang some shit again lol what amp are you running?? The amp will be Rockford T1500-1bdCP Oh yeah, and the rest of the Sub specs from Fi are: (Dual 2) DUAL 1 | DUAL 2 Fs: 34.2 Hz | 33.9 Hz Re: 0.7 Ohms/coil | 1.4 Ohms/coil Qms: 7.63 | 7.69 Qes: .39 | .39 Qts: .37 | .37 Mms: 249g | 253g Cms: 0.87mm/N | 0.87mm/N Sd: 481cm^2 | 481cm^2 Vas: 28.3 l | 28.3 l Spl: 86.5dB 1W/1m | 86.3dB 1W/1m Bl: 13.9 N/A | 19.65 N/A Xmax: 28mm Rms: 1500W Sealed box: .8-1.5 Ported box: 1.8-2.5 cuft @ 28-33Hz Sub OD: 12.500” Cut ID: 11.125” Mounting depth: 7.000” Displacement: 0.16cuft Thank you to everyone that has shared some ideas, I really appreciate everyones input. Spencer Quote Link to comment Share on other sites More sharing options...
Mikey Bates Posted August 7, 2012 Report Share Posted August 7, 2012 (edited) try this Edited August 7, 2012 by Mikey Bates Quote Link to comment Share on other sites More sharing options...
Jessica Posted August 7, 2012 Report Share Posted August 7, 2012 (edited) Just remember when doing your cut sheet if you have a port bend measure down the center of port. If you are going to put 45's in the corners then don't forget to add what they displace to the bracing box in torres. With a 32 inch long box i would put a 1" round dowel or two between the port wall and the box face for extra strength. You also have 1 extra baffle and i believe torres assumes it is internal. With 14" width and height that gives you 12.5 X 12.5 to mount, so how are you going to get the port in there? edit: sorry tat gives you 12.X 14, still don't see a two inch wide port and having the sub both in a 14" tall space. What is the cutout size for that sub, and what is the total diameter of the face? Edited August 7, 2012 by strangeduck Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Mikey Bates Posted August 7, 2012 Report Share Posted August 7, 2012 making a 3d model now Quote Link to comment Share on other sites More sharing options...
seaudio Posted August 7, 2012 Author Report Share Posted August 7, 2012 try this I wish I knew how to use a good sketching program, but since I do not, here is the basic concept. My question is, should I be concerned at all that I just have a long straight port versus an L shaped port? Quote Link to comment Share on other sites More sharing options...
seaudio Posted August 7, 2012 Author Report Share Posted August 7, 2012 making a 3d model now Mikey - I really appreciate all your help Thanks again to everyone that has helped out with ideas, I truly appreciate everyone's ideas and comments. Spencer Quote Link to comment Share on other sites More sharing options...
Jessica Posted August 7, 2012 Report Share Posted August 7, 2012 You wont get a 12" sub and a 2" port in a 14" tall space. If you can go a bit taller you can make it work, but it will be tight. here is an idea, let me know what you think Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Jessica Posted August 7, 2012 Report Share Posted August 7, 2012 (edited) you can change that port length to 29.25 and ommit the bend and you will be fine, edit, what i mean is, run the port to within 2" of the back of the box and you will have a 29.25" long port @ 34hz Edited August 7, 2012 by strangeduck Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Mikey Bates Posted August 7, 2012 Report Share Posted August 7, 2012 Ok here are some picture. the port and sub withh face up, and the port will be in the very back, the sub being closer to the front, and the empty surface area is weher you can put you console thing. cutting the double baffle for the port will be a bitch honestly but thats what you gotta do. and that 1.5" of port going through the baffle was calc into the port length so Quote Link to comment Share on other sites More sharing options...
Mikey Bates Posted August 7, 2012 Report Share Posted August 7, 2012 oohhh you were saying fire it forward lol. i was thinking up, i can change it if you want ( sorry for the misunderstanding lol) whatever, gives me something to do durng work :/ so slow Quote Link to comment Share on other sites More sharing options...
