Tee Washington Posted August 7, 2012 Report Posted August 7, 2012 I have a dodge magnum,I wanted to know could i run my power wire directly from battery in trunk or do i have to get 20+ feet of wire and run from front?
teamace24 Posted August 7, 2012 Report Posted August 7, 2012 If your batt is in the back then thats where you get your power from. Did a friends magnum and his battery was in the trunk as well and it was very easy. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
Guest Posted August 7, 2012 Report Posted August 7, 2012 if my memory serves me correctly, the battery is in the trunk in those cars. If you want to add an amplifier of decent size, i suggest that you run a new 0 gauge wire from the alternator to the battery in the trunk. then ground the same battery to the frame or strut tower, with the paint sanded off. edit: then yes, you hook the amplifier up to the rear battery, fusing the power line of course.
Tee Washington Posted August 7, 2012 Author Report Posted August 7, 2012 Preciate the help guys,thats gon save me a few dollars on 0 gauge
