Cameron O'Neill Posted August 12, 2012 Report Posted August 12, 2012 Hey guys, finally joined the site, been browsing around for a while, but I have come across a problem and I hope I can get some help with it. One of my subs keeps going out on me, I originally fixed it by switching the terminals on the sub, but it looks like both are burnt. Im trying to figure out what is causing this, I attached some pictures to show what I mean. Are they being overpowered, I bought this car with everything in it, so I'm not sure on the specs of the amp, but the subs are 1000 W peak 500 RMS Quote
imnew59585 Posted August 12, 2012 Report Posted August 12, 2012 (edited) what is the name and model of the amp. also have you had the problem before you switched the terms Edited August 12, 2012 by imnew59585 Quote
Cameron O'Neill Posted August 12, 2012 Author Report Posted August 12, 2012 (edited) what is the name and model of the amp. also have you had the problem before you switched the terms Im not sure, there are two amps in the car, one is under the driver seat and the other under the passenger seat. I cant see what the model numbers are on them and there bolted down and I dont really want to rip them out if I dont have to. And ya it burnt out the one terminal so I switched it to the other one and now it burnt out that one. Edited August 12, 2012 by Cameron O'Neill Quote
imnew59585 Posted August 12, 2012 Report Posted August 12, 2012 (edited) hmmmmmmmmmmmm, well you may have a blown sub but im not so sure tho. Edited August 12, 2012 by imnew59585 Quote
Cameron O'Neill Posted August 12, 2012 Author Report Posted August 12, 2012 (edited) If it helps, I got the amp model, its a Rockford Fosgate bd 500.1 The other amp is a caption audio, pretty sure its hooked up to the door speakers though. Edited August 12, 2012 by Cameron O'Neill Quote
imnew59585 Posted August 12, 2012 Report Posted August 12, 2012 (edited) do you have 1 or 2 sub set up?, also did this just start having the problem? Also what is the brand of sub Edited August 12, 2012 by imnew59585 Quote
DTS909 Posted August 12, 2012 Report Posted August 12, 2012 Had a friend buy a avalanche with a system in it and it was hooked up all wrong. Would be a good idea to redo the wiring from start that way you know for sure its hooked up right. Quote VM-1 Pioneer DEH-80PRS Hertz HSK 165XL Arc Audio KS 300.2 Linear Power 1002 Full Mods Fi Audio Q 10s Sundown Audio Scv 3000 Big 3 XS Power D5100 Juice Box 20AH Singer Alternator Sky High Wire <p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Cameron O'Neill Posted August 12, 2012 Author Report Posted August 12, 2012 (edited) do you have 1 or 2 sub set up?, also did this just start having the problem? Also what is the brand of sub 2 10's in a sealed box and they are Kaption Audio and yea it just recently started happening. Edited August 12, 2012 by Cameron O'Neill Quote
Cameron O'Neill Posted August 12, 2012 Author Report Posted August 12, 2012 Had a friend buy a avalanche with a system in it and it was hooked up all wrong. Would be a good idea to redo the wiring from start that way you know for sure its hooked up right. I would, but I have no idea where to start, and it looks like it was professionally done. Quote
Guest Posted August 12, 2012 Report Posted August 12, 2012 are the connections loose on the terminals Quote
