diffrent battery voltages?
Ok so I just installed my rear battery its a shrunken bt-120. It reads 13.56v.
My front battery is a acid interstate, it reads 14.06.
Is this normal or is there something wrong here
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
& off resting voltage is 12.88 in the rear
Can anyone answer this cause I'm kinda worried my rear battery might be bad
Seems pretty high for resting voltage, load test it, make sure it passes. Might be overcharged. Sounds like you have a faulty regulator.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
What wire have you got from front to back?
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Load test the rear batt or the front?
& I guess I will see tommrow when I start pulling 1500rms at 2 ohms
Should I let them load test it at auto zone?
Knuconceptz cca 1/0
My ground in the rear is good also
This is what my power wire is connected to in the front .
http://i1244.photobucket.com/albums/gg567/foxzachracing/IMAG0913.jpg
This is where my alternator drops off power. Also a very good shop around here told me this is the best place to run my power wire.
have you tried using the bat terminal on your front battery? I know it should all be the same, but give it a go
PSN: Rcp_soundz
i would used the battery post before i run off the stock fuse box.
Kenwood H/U
1/0 wire,
  • Who's Online   1 Member, 0 Anonymous, 1086 Guests (See full list)
