ABK1126 Posted September 3, 2012 Report Posted September 3, 2012 okay so i have 2 kicker 12" comps in a ported box it is a 4.1 cubic ft box the dimentions are 31x16x14.5 and they are hooked up to a kicker 400.1 with tht said i think we all know tht this amp puts out 400 watts at 2 ohms and 200 watts at 4 ohms well my subs r currently wired at 4 ohms at the amp so their only getting 200 watts and when i turn the volume up and turn up the bass level on the kicker remote my amp shuts off once i back the bass level on the remote jst a bit it starts playing again i dont understand why it does that they should handle that amp like nothing and like i said their only taking 200 watts not even the full 400 and if i wire them in parallel for a 2 ohm load well its even worse at 4 ohms when i turn up the volume on my hu bout 1/4th then the bass remote to about 1/2 it starts shutting off and at 2 ohms it starts shutting off not even at 1/2 way up on the bass remote please help me someone i also have a clarion eq the 7 band one and the sub level there is up to about half please help me with a solution to what the problem is it got profesionally hooked up a few weeks ago and the guy wired them at 4ohms i dont know why any help appreciated thanks
ABK1126 Posted September 3, 2012 Author Report Posted September 3, 2012 oh and if it matters my amps settings are gain about 50 percent crossover its around 80 and bass boost is off
Sonic Posted September 3, 2012 Report Posted September 3, 2012 If I am not mistaken those subs are single 4 ohm and 150 watts rms each, hence the can either be wired to an 8 ohm (series connection) or 2 ohm final load (parallel connection) with a total rms of 300 watts. At 2 ohms final load you will be giving them 200 watts rms each (over powered), At 8 ohms you will be giving them 50 watts rms each (low power). Additionally, your clarion eq is a 7 volt pre output, hence will need a lower gain setting. Try turning down your amp gain.
ABK1126 Posted September 3, 2012 Author Report Posted September 3, 2012 so the problem is my gains? i thought it was my sub box?
