SlamminBeats Posted September 10, 2012 Report Posted September 10, 2012 should i buy an av reciever? ive also seen a plate amp that powers a sub and two speakers on parts express? Also have seen some class T amps What route should i go?
rock4016 Posted September 19, 2012 Report Posted September 19, 2012 The low watt class T would be the cheapest, but probably wouldn't be enough power for the lowest notes. The higher watt (say 50W and up) class T are still affordable, PE has them for $89. The PE Dayton BR-1 kit gives pretty good bass for an inexpensive home bookshelf size speaker. They also sound decent quality metal stands that would work great for them if you don't have something in place already. If you did get the BR-1 kit I'd use Dennis Murphy's modded crossover you'll also get very good quality sound that may not even need a sub, depending on your room and tastes. For example, I have a set in a bedroom system and the speakers are close to the wall behind them (about 8"). In that room, I don't feel the need for a sub. If the lowest notes must be played loud, PE also have several subs and sub kits that should blend well with the BR-1.
Tito DeLatorre Posted October 3, 2012 Report Posted October 3, 2012 Get a Power amp and a Mixer and 2 1/4 cables and you're in business. Fi SSD 15" d2 on a SPA2000 at 2.8 ohms SPA2k: 1150 at 4 ohms per channel 750 at 8ohms per channel. 2k at bridged 8ohms mixer cost me roughly 150$ due to me doing live audio sound for local shows. should only cost 50 bucks as its a Linelevel signal processor(idea anyways) cables cost me like 8-12 bucks each amp 260+tax i use to run a hifonics brutus1200 and 1700 on a battery and charger in my room, little bit dangerous, and i'm now able to get over 600watts rms.. i don't ever go that high(unless my friends are around). fucking shakes my entire house haha.
SlamminBeats Posted October 3, 2012 Author Report Posted October 3, 2012 i bought a 7.1 receiver that does all channel stereo for 81 shipped cant beat that
Tito DeLatorre Posted October 3, 2012 Report Posted October 3, 2012 i bought a 7.1 receiver that does all channel stereo for 81 shipped cant beat that yeah those receivers don't put out alot of power though.
SlamminBeats Posted October 4, 2012 Author Report Posted October 4, 2012 DD pa's dont need power to scream.
