Start of: "Big and Nasty" aka: Optimums
Well, it is finally time for me to start my build log of my 1997 4X4 K2500 6.5 Turbo Diesel Suburban. I am a huge believer in Diesel motors and love the power they can produce, also the somewhat rarity of a Suburban being Diesel. I have a lot of work planned for this build; as I will mention later I have done some major but unnoticeable to the eye fixes.
Things I fixed already:
1. Both Rear air and Front fixed to perfect working order.
2. Steering fixed(Tie end rods, bearing at the bottom of the power steering knuckle, a few more issues I can't recall)
3. New Oil cooler lines and cooler
4.PMD relocate to bumper
5. New Fuel lines around fuel filter.
6. Duramax Diesel Clutch fan
7. 195 degrees thermostat
I have many interior mods and exterior mods planned along with a fairly decent stereo system.
The interior plans I have for this Vehicle is as Follows:
1. Change the interior color from gray to Factory GM Royal Blue - I have all the pieces to finish this swap other then buying new carpet that will be bought after I sound deaden the floor.
2. Make a custom gauge cluster using all Auto meter pro comp gauges, with the driver side A pillar containing Boost, and EGT.
3. Put White Led's in all light Sockets - already ordered.
4. All stereo Equipment modifications, still planning certain area's.
Exterior Mods:
1. Tires and wheels- already bought
2. Front brush guard - Sand blasted and powder coated black, Done.
3. New light fixtures all the way around with HID conversions - Everything bought except for led taillights because I can't find any ones I like(Help Needed).
3. New OEM Grille - Bought
4. New Side Mirrors - Bought
5. Bush Wacker fender flares - More thinking
6. Two sets of Hella Off-road lamps, HID conversion, 1 set 5000k, 1 set 3000k(fog)
7. Along with other things I happen to decide to do.
8. 4 inch turbo back straight pipe exhaust with chrome 5 inch tip
Stereo Equipment(Not final)
1. Alpine 137bt - Deck
2. 2 Sundown Audio SA-12's
3. Dc power 185 Alternator
4. Big 3, battery iso, 2 batteries up from(Top of the Line Interstate Deep cycles) 1 Rear(Xs Power D1200)
5. 1/0 Front to back
6. Clarion EQ, Or if I can find a reasonable priced Processor.
7. Going to Try Cadence speakers all the way around to see if I like them, If Not I will Try something else. 6 6.5's, 2 8's. 4-6 super tweeters.
8. Amps( This is the thing that is giving me the most trouble... If anyone could assist me I would greatly appreciate it. Looking at mid range amps)
That is all for the small intro. Now for some pictures.
Building an Empire.
Tuned! I love these GMCs... just wish they were a bit cheaper over here! Keen to see what you do with it
In terms of amps, depending of your price range the AQ 120.4 seems pretty good, that is what I will be running once I get teh $$ but I don't have first hand experiance with it... yet.
Thank you for the feed back! I am excited to see where this thing takes me! I love working on my own vehicle's and seeing how I can inprove on them. Ordering more parts as we speak.
Building an Empire.
No worries, few others you can look at depending on the $$ your wanting to spent, DC 175.4, Sundown SAX100.4D, Skar 85.4. Few ideas anyway depending on how much you want to spend.. I don't have any experiance with them but they are what I've seen used on the forum. Good luck!
