cartunez2004 Posted January 17, 2008 Report Posted January 17, 2008 ok i need help on fuse size going from the front battery to the back battery im running two runs (2+,2-) of 2/0awg(its like welding cable) and plan on using 300a ANL fuses, one on each of the + wire in the front and one on each close to the back battery is that ok or should i use a smaller one. also need to know what size fuse i need to put on the the alternator wire from the big 3 upgrade i have a 260amp excessive amperage let me know thanks new toy 97 chevy s10 ext cab bagged 22s system (coming soon ) 4 soundstream t4-15s walled 2 concept 2410 mono amps REFS http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004 http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
cartunez2004 Posted January 17, 2008 Author Report Posted January 17, 2008 o yea im running two concept 2410s one to each sub and two concept 4 channels amps for the mids and highs new toy 97 chevy s10 ext cab bagged 22s system (coming soon ) 4 soundstream t4-15s walled 2 concept 2410 mono amps REFS http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004 http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
audioman21 Posted January 17, 2008 Report Posted January 17, 2008 I'm pretty sure your supposed to use the biggest fuse rated for the wire.Those 300a fuses should be ok for the positive runs and alt.
cartunez2004 Posted January 17, 2008 Author Report Posted January 17, 2008 I'm pretty sure your supposed to use the biggest fuse rated for the wire.Those 300a fuses should be ok for the positive runs and alt. thanks bro anyone else have imput new toy 97 chevy s10 ext cab bagged 22s system (coming soon ) 4 soundstream t4-15s walled 2 concept 2410 mono amps REFS http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004 http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
dmanson Posted January 17, 2008 Report Posted January 17, 2008 I'm pretty sure your supposed to use the biggest fuse rated for the wire.Those 300a fuses should be ok for the positive runs and alt. he said it all bro 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
