Help Wit Fuse Size From Front To Back Battery And Alternator
ok i need help on fuse size going from the front battery to the back battery im running two runs (2+,2-) of 2/0awg(its like welding cable) and plan on using 300a ANL fuses, one on each of the + wire in the front and one on each close to the back battery is that ok or should i use a smaller one.
also need to know what size fuse i need to put on the the alternator wire from the big 3 upgrade i have a 260amp excessive amperage let me know thanks
new toy
97 chevy s10 ext cab
bagged
22s
system (coming soon )
4 soundstream t4-15s walled
2 concept 2410 mono amps
REFS
http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004
http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
o yea im running two concept 2410s one to each sub and two concept 4 channels amps for the mids and highs
new toy
bagged
22s
REFS
I'm pretty sure your supposed to use the biggest fuse rated for the wire.Those 300a fuses should be ok for the positive runs and alt.
thanks bro anyone else have imput
new toy
bagged
22s
REFS
he said it all bro
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 1270 Guests (See full list)
